Hi Matt,
No. But the logical order would be:
DAC0 = X DAC1 = Y DAC2 = Z
As well as
Axis channel 0 = X,
Axis channel 1 = Y,
Axis channel 2 = Z.
As well as
Encoder channel 0 = X
Encoder channel 1 = Y
Encoder channel 2 = Z
But for now just concern yourself with the DACS
Message: 7282 |
Date: 4/16/2013 |
Subject: Re: Knowledge base and "lingo" |
Ok I got the three axis hooked up and I did put them in XYZ order does this look correct?
http://groups.yahoo.com/group/DynoMotion/photos/album/1879334121/pic/list
> Hi Matt,
> DAC0 = X
> DAC1 = Y
> DAC2 = Z
> As well as
> Axis channel 0 = X,
> Axischannel 1 = Y,
> Axischannel 2 = Z.Â
> As well as
> From: mattbsemail <mattbsemail@...>
> Sent: Friday, April 12, 2013 5:21 PM
> Subject: [DynoMotion] Re: Knowledge base and "lingo"
> Ah I see JP11. So is there any order to put the Axis' in
> --- In DynoMotion@yahoogroups.com, TK <tk@> wrote:
> > Hi Matt,
> > You might try researching on the Internet or Google. A DAC is a digital to analog converter. Or like an electronic potentiometer. You put a digital number in and out comes a voltage. Kanalog has 8 of them. See
> > http://dynomotion.com/Kanalog.html
> > On Apr 12, 2013, at 2:29 PM, "mattbsemail" <mattbsemail@> wrote:
> > > Well I had already done that with a 9V and a potentiometer. All 3 motors turned cw, ccw, and it was looking good.
> > > I don't know what DAC means.
> > > > Hi Matt,
> > > > Check out cnczone.com there is tons of info.
> > > > But the first step is to see if you can get your motors to turn by applying a small voltage to the amplifier +/- 10V analog input. You might start with a 1.5V battery. The motor should run at 15% full speed. Reversing the battery should run the motor the opposite direction.
> > > > If that works, connect a Kanalog DAC instead of the battery. Then try to command motor speeds using the KMotion Console Screen with commands like DAC0=200
> > > > Regards
> > > > TK
> > > > On Apr 12, 2013, at 11:28 AM, "mattbsemail" <mattbsemail@> wrote:
> > > > > So I bought a KFLOP atop a KAnalog and it's just been sitting because I've been way too busy with work. I have mounted it inside a computer case and I setup the power supply already. Then I had to order encoders it took 2 months and I pretty much let the project die. I have about $5k in it so far and I would like to finish but I have no idea where to start. Is there a place I can learn to retrofit a 3 axis CNC mill? I have a serious lack of knowledge on where to start and how to go about doing this. It is a Kasuga w/ a bandit control. Any and all help will be greatly appreciated. Thanks for your time! Matt
Message: 7283 |
Date: 4/16/2013 |
Hi Matt,
Yes those are the Kanalog DAC Outputs. But what did you connect them to?
Message: 7285 |
Date: 4/16/2013 |
Sorry for the slow response. Those are my signal wires for x y and z. Are those the ones I want to hook up?
http://groups.yahoo.com/group/DynoMotion/photos/album/1879334121/pic/664600576/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc
> Hi Matt,
> Sent: Tuesday, April 16, 2013 6:41 PM
> > Hi Matt,
> > No.ÃÂ But the logical order would be:
> > DAC0 = X
> > DAC1 = Y
> > DAC2 = Z
> > As well as
> > Axis channel 0 = X,
> > Axischannel 1 = Y,
> > Axischannel 2 = Z.ÃÂ
> > As well as
> > From: mattbsemail <mattbsemail@>
> > ÃÂ
> > > Hi Matt,
> > > > > Hi Matt,
> > > > > Regards
> > > > > TK
Message: 7287 |
Date: 4/17/2013 |
Hi Matt,
Are you expecting someone to know what that picture of the connector on your machine is?
Don't you have any wiring diagrams of your
machine?
Message: 7288 |
Date: 4/18/2013 |
Hi Matt,
Retrofitting a mill is a lot more like putting a different engine in your car than putting new rims and a body kit on it. Every machine is different, and the manufacturers didn't design them to be deciphered.
I wouldn't recommend this as a project unless you're at least basically comfortable with a meter and an oscilloscope as well as soldering and working with standard electronics (reading datasheets, relays, wiring and testing 5V logic). It's definitely a whole different can of worms retrofitting an industrial machine VS a hobbyist control like a Mach 3 machine with Geckos which was designed to be easy to fiddle with.
> Hi Matt,
> Don't you have any wiring diagrams of your machine?
> Sent: Tuesday, April 16, 2013 6:59 PM
